02-13-2016 13:09
02-13-2016 13:09
I am creating a Rails app that uses the Fitbit API, and need to do this in a test driven way. There are certain pages that a user should not see if unless they have logged in with their Fitbit account. This is all working.
The problem is trying to write tests. I am trying to test various things on the pages that only logged in users can see, but setting up the tests (in RSpec and Capybara) is proving difficult, as I have to find a way to "mock" a Fitbit login first. I don't want to put my own details in the tests (the repo will be open source). Is there such a thing as a test Fitbit user? Or is there another simple way to do this without inputting real login details?
02-15-2016 12:54
02-15-2016 12:54
Please don't create test users on Fitbit.
I suggest mocking/stubbing the Fitbit interactions for automated tests.
02-15-2016 12:54
02-15-2016 12:54
04-07-2016 10:46
04-07-2016 10:46
Hi, I have a similar question. We are getting ready to run a 1,000 person load test but with just one user we will run into the API rate limit of 150 per hour, right away. Do you have another suggestion so that we can run a full load test?
04-07-2016 12:11
04-07-2016 12:11
@JonathanAlta: You should be load testing your application, not the Fitbit API. If you want to simulate the Fitbit API, you should create a mock API.
08-05-2024 09:32
08-05-2024 09:32
This is a very incompetent answer, developers just want a test account, how hard is to create one for people to test different endpoints? haha
