10-28-2016 08:34
10-28-2016 08:34
Hello everyone,
is it possible to get the access_token with Implicit Grant Flow with curl ???
curl -X POST -i -H 'Authorization: Basic XXXX'
-H 'Content-Type: application/x-www-form-urlencoded'
-d "response_type=token" -d "client_id=XXXX"
-d "grant_type=authorization_code"
-d "scope=activity%20heartrate%20location
%20nutrition%20profile%20settings%20sleep
%20social%20weight" -d "expires_in=604800"
-d "redirect_uri=https%3A%2F%2Fexample.com%2Fcallback-url"
https://www.fitbit.com/oauth2/authorize
When i post the information with curl,naturally withaut the newlines i get know no access_token.
Response:
HTTP/1.1 302 Found Date: Fri, 28 Oct 2016 15:24:19 GMT Content-Length: 0 Connection: keep-alive Set-Cookie: __cfduid=d857702b848e69e215ec54085acfca5151477668258; expires=Sat, 28-Oct-17 15:24:18 GMT; path=/; domain=.fitbit.com; HttpOnly X-UA-Compatible: IE=edge,chrome=1 Set-Cookie: fhttps=""; Expires=Thu, 01-Jan-1970 00:00:10 GMT; Path=/ Location: https://www.fitbit.com/login?redirect=%2Foauth2%2Fauthorize%3Fclient_id%3XXXXX%26expires_in%3D604800%26redirect_uri%3Dhttps%253A%252F%252Fexample.com%252Fcallback-url%26response_type%3Dtoken%26scope%3Dactivity%2Bheartrate%2Blocation%2Bnutrition%2Bprofile%2Bsettings%2Bsleep%2Bsocial%2Bweight%26state Content-Language: de-DE X-Frame-Options: SAMEORIGIN Server: cloudflare-nginx CF-RAY: 2f8f64d7de0d265a-FRA
11-01-2016 12:15
11-01-2016 12:15
@pe_Mani_rl The access token will be a url fragment once the app has been authorized by the user.
The reason it's redirecting here:
https://www.fitbit.com/login?redirect [...]
is because there's no user logged in when you're trying to auth.
Best Answer11-07-2016 02:07
11-07-2016 02:07
Thank you Andrew for the response,
i must be blind i can`t find in the RFC 6749 no username and password example for the Implicit grant flow
authentication :
GET /authorize?response_type=token&client_id=s6BhdRkqt3&state=xyz
&redirect_uri=https%3A%2F%2Fclient%2Eexample%2Ecom%2Fcb HTTP/1.1
Host: server.example.comis the example for the implicit grant flow authentiaction. I want to write a explicit perl library for fibit.
At the moment i paste the code from the Authorization Code Grant Flow url fragment hardcoded in the constructor and save the access_token in a temp file only for trying my methods. I find is a better way to get the access_token without to saving in a temp file . Can you support me a little bit Iám to silly to unterstand why i cant get access_token directly with curl or is not possible with curl ? Or can I set an username and password with curl and which username and password is ment ?
Best Answer11-08-2016 08:36
11-08-2016 08:36
@pe_Mani_rl I've never used cURL, but I'm assuming you'll have to do something like this. Once you have a user logged in, you should be able to get an access token, which will be a url fragment (for Implicit Grant Flow).
Best Answer11-17-2016 02:39
11-17-2016 02:39
Now it works thanks, but is it a good idea to use email and password with post ??
Is this secure ?
The api docu writes :
Implicit Grant Flow Fitbit follows the OAuth 2.0 Implicit Code Grant as specified in RFC 6749. Fitbit strongly recommends that you review the specification and use an OAuth client library for your programming language. The Implicit Code Grant Flow has the following steps: "The Logon Page open" 1. Your application redirects the user to Fitbit's authorization page. See Authorization Page below. 2. Upon user consent, Fitbit redirects the user back to your application's redirect URL with an access token as a URL fragment. 3. Your application stores the access token client side. It will use the access token to make requests to the Fitbit API.
