11-27-2018 16:22
11-27-2018 16:22
I am currently pulling data from Daily Activity Summary (https://dev.fitbit.com/build/reference/web-api/activity/) and have several questions about the following fields:
08-09-2020 12:41
08-09-2020 12:41
Why aren't there data dictionaries for these? I've seen requests since 2016
Best Answer08-19-2020 14:50
08-19-2020 14:50
Hi @sleepy_dave,
Apologies for the very late response.
@sswift Thanks for the suggestion, we are aware that this is a widely requested item and is being considered.
I hope this helps. Please let me know if you have any other questions.
Best Answer09-21-2022 17:56 - edited 09-21-2022 17:57
I've been searching for the same thing, and @JohnFitbit I appreciate your response here, but it doesn't seem to be accurate. Here's what the Fitbit Activity API reports for me for yesterday (omitting other fields):
https://api.fitbit.com/1/user/-/activities/date/YYYY-MM-DD.json
"summary": {
"activityCalories": 3468,
"caloriesBMR": 1774,
"caloriesOut": 4601,
"marginalCalories": 2320
Clearly the caloriesOut element is NOT the total sum of activityCalories + caloriesBMR (which would be 5242 not 4601). For what it's worth I didn't manually log anything, all the data is from my tracker, though I also didn't start/stop activities on the tracker, so the activities it captured were just ones it deduced from the data.
I've also not found a definition for marginalCalories.
Best Answer09-23-2022 06:35
09-23-2022 06:35
Hi @ammulder
Let me double-check with engineering on this. While the generalized calculation is caloriesOut = caloriesBMR + activityCalories, it's possible our internal algorithms changes a bit.
I don't have any historical information on what marginalCalories is. We did research this topic last year and worked with our research and engineering teams, but couldn't come up with a concrete answer at the time. I can look into it again.
09-28-2022 06:46
09-28-2022 06:46
Hi @Gordon-C , were you able to get a response from engineering?
I had to laugh a little, thinking, we're all developers here, maybe you can just post the code! 😉
Best Answer01-19-2023 08:42
01-19-2023 08:42
Any updates here @Gordon-C ?
Best Answer01-19-2023 08:50
01-19-2023 09:15
01-19-2023 09:15
I searched the forum for "marginalCalories", and I see a post elsewhere that this field is deprecated and should be ignored.
