07-25-2017 19:55
07-25-2017 19:55
Hi All,
I am kinda new to the fitbit api. I am trying to get the daily summary for distance, but I keep getting back data that doesn't match the users fitbit app. For instance, I get back a daily summary of 2.47 and the user reports thats wrong and it should be 1.84. I have tried ALL calculations on the distance returned and nothing is adding up to what she is saying she is showing in her app. So I am kinda confused as to how I should be calculating the distance to display to a customer on our site. Any one have any insight on this? I'll paste a response below:
{"dateTime":"2017-07-16","value":"5.74535"}She is reporting that on this day, her fitbit is saying 3.57 miles. Here is the response from the server when requesting those daily summaries:
"distances": [
"activity": "total",
"distance": 5.75
"activity": "tracker",
"distance": 5.75
"activity": "loggedActivities",
"distance": 0
"activity": "veryActive",
"distance": 0.67
"activity": "moderatelyActive",
"distance": 1.65
"activity": "lightlyActive",
"distance": 3.42
"activity": "sedentaryActive",
"distance": 0
]As you can see, it clearly matches up with what we are showing her, but definitely not what she says is displaying in her app. The endpoint I am calling is
activities/tracker/distanceCan anyone point me in the right direction? I am kinda at a loss here and am not sure how this is actually calculated. Any help is greatly appreciated. Thanks Community!
07-31-2017 07:31
07-31-2017 07:31
@Taddy_Mason The data is returned in metric units so that would be correct.
In the example you gave, 5.75 km = 3.57 miles.
Best Answer07-31-2017 07:31
07-31-2017 07:31
Best Answer07-31-2017 07:33
07-31-2017 07:33
Yep! I figured that out the other day that it was coming back in Kilometers. I didn't see it in the docs, but I could have easily overlooked it. Thanks for the answer!
06-06-2018 00:11
06-06-2018 00:11
https://api.fitbit.com/1/user/-/activities/tracker/distance/date/2018-06-05/2018-06-06.json
Will this API always return Distance in kilometers even I setup my Distance Unit = Miles in the Fitbit App?
Best Answer06-12-2018 09:35
06-12-2018 09:35
@SowmiyaMadesh We will send the data back in the unit defined by the Accept-Language header. The Accept-Language values "en_US" and "en_GB" are case sensitive. If you use the Accept-Language header en_US, then your distance unit data should return in miles.
https://dev.fitbit.com/build/reference/web-api/basics/
