07-10-2017 10:20
07-10-2017 10:20
Hi API support forum,
we are using Fitbit Charge 2 models to collect activity data for a research study. I was wondering if there is any limit on how long data is stored? E.g. will intraday data be deleted after a certain time - 1 month, 1 year, 2 years?
Thanks,
Theresa
08-11-2017 09:38
08-11-2017 09:38
From what I understand, and keep in mind that I don't work for Fitbit, the data is preserved indefinitely and not deleted from Fitbit's server.
For instance, I have data going back to 2/28/2011, and I'm able to retrieve the daily data, and intraday data. Also, in my dissertation research I enrolled a participant who had data going back to December 2009 (this participant was an early pre-orderer of the original Fitbit), and was able to access their data using our Fitabase data management platform.
Hope this helps!
07-10-2017 15:39
07-10-2017 15:39
Hi,
I can help with this. You can view the relevant help page here on syncing devices. The important point is:
A daily sync is recommended but not required. Most Fitbit trackers record detailed minute-by-minute data for seven days. (Fitbit Alta records minute-by-minute data for five days). Fitbit trackers can store daily totals for up to 30 days.
When working with researchers we typically recommend they have participants sync devices every 5 days just to make sure there is a bit of wiggle room in there. It is very important to sync at least once every 7 days for access to minute-by-minute data for steps, activity intensity, and energy expenditure, as well as second-level heart rate data, and sleep logs. Sleep data particularly important as it is processed at Fitbits servers and needs to have access to that higher resolution data to create sleep logs.
Hope this helps. If you have more questions about using Fitbits in research, or how you can easily access Fitbit data from
Best Answer07-10-2017 15:40
07-10-2017 15:40
Hi,
Hope this helps. If you have more questions about using Fitbits in research, or how you can easily access Fitbit data from a unified data management suite, just let me know.
07-11-2017 04:38
07-11-2017 04:38
Hi,
thanks for your fast response! I was familiar with the documentation about the duration data is stored until it needs to be synced. My question was more alluding to how long the data will be available on the API/the server once it has been synced. For example, will I still be able to access intraday data from every single day 5 years from now?
Best
Theresa
08-11-2017 02:11
08-11-2017 02:11
Did you find out by now?
Best Answer08-11-2017 08:31
08-11-2017 08:31
No, unfortunately not.
Best Answer08-11-2017 09:38
08-11-2017 09:38
Hope this helps!
