Device id is not unique for Mobile Track
We built our system under the assumption that device ids are unique in fitbit's system. We are now having an issue where a user cannot connect because device id already exists. Both users are using Mobile Track. Can a fitbit party confirm that device ids are unique or not? Thank you.
3 REPLIES 3
Can anyone provide us with some information on how device ids are generated, we're still having issues with device ids not always being unique. Device ids are used as a lookup in our system and in some cases two fitbit devices have the same device id in the fitbit system.  Thank you
hi @SteveWT, do you mean ID's coming form the user/-/devices.json end point?
My experience is they are unique to a user using the device, so if you give a device with soemone else they will get a new device id even though the device is technically the same.
Is that what you mean? or are you looking at a different ID?
Ionic & Aria, Blaze (retired), Alta (retired), Surge (retired), Charge HR (retired), One (retired), Classic (retired) | Microsoft Surface | Google Pixel 2XL Android FitBit App
Device IDs are unique, even for MobileTrack.
