Under resource URLs in the Get Activity Intraday Time Series (https://dev.fitbit.com/build/reference/web-api/activity/#get-activity-intraday-time-series), this is one of the reference API calls:
GET https://api.fitbit.com/1/user/-/[resource-path]/date/[date]/[date]/[detail-level].jsonBut [date] is listed twice. In other API calls, there are elements such as [base-date] or [end-date] to be able to pull this data for a date range.
Is this an error and should those elements reference start & end dates?
Or is there just not a way to pull intraday activity for a particular date range?
Thanks!
Hi @cwebster_nymbly,
Thanks for pointing this out. This is indeed incorrect syntax and should be [base-date] and [end-date] for the endpoints that support date range. I'll go ahead and file a ticket to get these fixed.
Thanks again!
Thanks again!
