Hello,
How do i combine and export data collected from multiple fitbit sources(Users) into a sql database using an API. Any leads will be highly appreciated.
Thanks.
Hi @Hrc-
My apologies for the delay. I'd recommend using the Web APIs to retrieve the user data. See Web API Documentation. Each endpoint is going to provide you data for a single user. You will not be able to combine user data through the endpoint execution. The response is going to be presented in JSON format. I believe some databases can read and parse JSON. If you want a generic solution, build a service that reads the JSON string and parses out the data values. I know there are lots of examples in Java and I've seen some for other languages. I'd probably reference the user id (or a mapping of the user id to a unique value ) as the key value in your table.
Gordon
I think I found something what you may find useful: https://github.com/DataScienceUNIVR/fitbit_api_database The app pulls data from API and saves it to the database.
