09-02-2015 15:28 - edited 09-02-2015 15:29
Hi all,
we have an application that pulls data from Fitbit for our users.
The problem is that for one of the users activity data are just impossible:
veryActiveMinutes: 1439 minutes,
distance (total): 164.76 miles
It is just impossible to cover such a distance in such a time even by car.
Is it something wrong with the tracker? How to investigate such cases?
Thanks.
09-09-2015 10:11
09-09-2015 10:11
By the way,
I have received response from Fitbit tech support, maybe it will help someone who has the same issue:
This is a known issues and we're currently working on a fix. At this time, we don't have a way to correct the data.
We apologize for any inconvenience this may have caused.
09-02-2015 15:44 - edited 09-02-2015 15:44
It's possible that the person has a defective device. The person may have logged a manual activity log. The person may be attempting to fake activity data by immitating ambulatory activity (such as attaching it to a swing or spinning wheel).
You can get a list of manually logged activities by requesting the daily activity summary. They'll be listed in the 'activities' array.
You can get data recorded by the tracker without manually logged activities by requesting the 'activities/tracker/*' time series.
Might also be worth checking if the person has MobileTrack enabled by requesting the device list. This feature allows people to use the activity tracking feature of some smart phones, but smart phones generally are not as accurate as Fitbit devices and can be manipulated.
09-02-2015 15:54
09-02-2015 15:54
Thanks for prompt reply.
So it might be either broken device or cheating - we are using activity summaries endpoint, 'total' distance is equal to 'tracker' so I assume this is what we get from device only.
Thank you again.
09-09-2015 09:22
09-09-2015 09:22
@maksym wrote:Hi all,
@maksym Covering 164 miles in 1439 minutes would be something like 7 miles per hour. Certainly can be done in a car. And someone could even jog at that speed, but really 24 hours of continuous very active time sounds like what @JeremiahFitbit said: either a broken device or cheating.
09-09-2015 10:07
09-09-2015 10:07
Yes, you are absolutly right, I also realized that later, thought I will return and correct that. But as usually forgot 🙂
I was copying 'minutes' from my app, but was thinking in 'seconds'.
09-09-2015 10:11
09-09-2015 10:11
By the way,
