12-24-2014 04:47
12-24-2014 04:47
Hi,
I'm using Fitbit API to sync with Flex, but when fetching the user's activities, i got only the logged activities from the web dashboard not recorded by the Flex tracker.
Any hint?
Thanks.
01-04-2015 19:39
01-04-2015 19:39
Unfortuantely the API does not expose Activity Records (annotations created on the tracker). We hope to have this added to the API in the near future but I don't have a exact timeline for it.
12-26-2014 12:07
12-26-2014 12:07
Hello, do you see those activities that reported by your Flex tracker on fitbit.com?
Did you consider using timeseries APIs: https://wiki.fitbit.com/display/API/API-Get-Time-Series ?
12-27-2014 08:03
12-27-2014 08:03
- Using timeseries APIs will return the data from the tracker in daily listing, Is there any posibility to list like the activties listing?
- In timeseries API there is 4 activity duration types:
If my app saves the total duration for a tracker-logged activity i'm supossing to sum the last 3 types and save them?
Thanks for your reply.
12-29-2014 08:15
12-29-2014 08:15
Hello, please answer my first question above.
12-30-2014 03:09
12-30-2014 03:09
I see them reflected on my fitbit Dashboared, but i don't see them under Log/activities.
Thanks.
01-04-2015 07:05
01-04-2015 07:05
any help for this?
01-04-2015 19:39
01-04-2015 19:39
10-27-2016 06:58
10-27-2016 06:58
Do we have api available now to get the activities recorded by flex.?
10-27-2016 11:05
10-27-2016 11:05
@ranjitrathod No, the API still does not expose Activity Records.
10-27-2016 21:55
10-27-2016 21:55
is there any other way to get the activities which were recorded from flex?
Thanks.
11-01-2016 15:23
11-01-2016 15:23
@ranjitrathod No, unfortunately you won't be able to get activities recorded by a Flex because they show up as activity records.
11-01-2016 20:10
11-01-2016 20:10
11-02-2016 07:41
11-02-2016 07:41
@ranjitrathod I believe the only two devices that still use "Activity record" are the One and Flex.
