09-09-2016 10:26
09-09-2016 10:26
Does the API or will the API provide heart rate variability (HRV) information?
Best Answer09-09-2016 11:52
09-09-2016 11:52
@jeffbrandt HRV is not stored anywhere, it's only part of Charge 2's "Relax" feature. So since HRV data is not tracked (like steps, distance, HR, etc.), then you won't be able to pull that information.
09-09-2016 12:08
09-09-2016 12:08
thanks, Just checking
Best Answer05-11-2018 06:18
05-11-2018 06:18
Not good answer.
HRV is a calculation. Time between two beats. 😉
Not stored, that's correct, but if you have the heart rate in a high sampling rate, you can calculate the HRV!
Is that possible with the SDK?
I guess no. Am I wrong?
Regards,
Mark
Best Answer05-11-2018 14:31
05-11-2018 14:31
The time of individual beats is not recorded. The highest resolution data is BPM sampled every 1 to 3 seconds (or longer on older devices if not in an activity session).
