10-24-2016 23:31
10-24-2016 23:31
How do I retrieve longitude and latitude data with the use of python?
I saw "Get Activity TCX" and typed "Resource URLs".
-> Get Activity TCX...https://dev.fitbit.com/docs/activity/#get-activity-tcx
-> Resource URLs...https://api.fitbit.com/1/user/[user-id]/activities/[log-id].tcx
But error message below is displayed.
invalid_client - Invalid authorization header format.
Visit https://dev.fitbit.com/docs/oauth2 for more information on the Fitbit Web API
authorization process.
I was getting user_id from the profile endpoint and log-id from Activity Logs List.
Please tell me what is a problem.
10-26-2016 10:38
10-26-2016 10:38
@WA1 You'll need to send the access token, should be something like this:
Authorization: Bearer accesstokenforuser
10-25-2016 11:27
10-25-2016 11:27
@WA1 Can I see the header you're setting?
10-25-2016 23:52
10-25-2016 23:52
My setting is as follows.
req = urllib2.Request('https://api.fitbit.com/1/user/4PNPB2/activities/4580023024.tcx')
req.add_header('content-type', 'application/vnd.garmin.tcx+xml; charset=utf8')
Thank you.
10-26-2016 10:38
10-26-2016 10:38
10-26-2016 22:01
10-26-2016 22:01
Oh!
I was able to get GPS data to send the access token.
Thank you so much!
10-27-2016 11:16
10-27-2016 11:16
@WA1 Awesome, glad you got it figured out.
