10-24-2016 13:32 - edited 10-24-2016 13:47
Hi all,
I am trying to figure out how Fitbit calculates the duration of activity minutes for minutes logged with a tracker. Here is the API output for
https://api.fitbit.com/1/user/-/activities/date/2014-11-19.json
"activities": [
"summary": {
"activeScore": -1,
"activityCalories": 819,
"caloriesBMR": 1759,
"caloriesOut": 2371,
"distances": [
"activity": "total",
"distance": 5.09
"activity": "tracker",
"distance": 5.09
"activity": "loggedActivities",
"distance": 0
"activity": "veryActive",
"distance": 0.8
"activity": "moderatelyActive",
"distance": 1.85
"activity": "lightlyActive",
"distance": 2.44
"activity": "sedentaryActive",
"distance": 0
"elevation": 45.72,
"fairlyActiveMinutes": 24,
"floors": 15,
"lightlyActiveMinutes": 135,
"marginalCalories": 480,
"sedentaryMinutes": 825,
"steps": 6899,
"veryActiveMinutes": 11
And here is what I see on the dashboard for that day:
I read this discussion on the same subject, which gives this answer: "Active minutes is a sum of veryActiveMinutes and fairlyActiveMinutes values in that endpoint."
But if you add what I'm getting for veryActiveMinutes (11) and fairlyActiveMinutes (24), you do not get 55:00. There are no other activity log entries on that day. On the left side of the dashboard it says 2:05 pm to 3:00 pm, but the API does not return any start or end time data.
Can anyone help? Thanks in advance!
Best Answer10-25-2016 12:24 - edited 10-27-2016 11:01
@n0tkat The second screenshot is an 'Activity record' that's showing calorie burn for that time frame. Activity record is a legacy feature and is not returned via the Web API.
Those active minute are for the entire day, it's not related to just the Activity record.
You can learn more about Active Minutes on our help site.
