12-27-2018 15:53
12-27-2018 15:53
Hi everyone,
I am a researcher at Monash University. I am planning an experimental study using activity trackers to study mind wandering and spontaneous thoughts, and the Fitbit Alta HR seems suitable for our purposes.
To make our study work, we will require access to the raw data from individual trackers. A summary of the data will not be sufficient for our study, which requires minute-by-minute recordings. We, the researchers, will also need to be able to access these data ourselves. In other words, it won't be enough for the data to be accessible on the participants' mobile phones. We will need the data to
| Fri, Nov 23, 7:02 PM |
12-27-2018 21:56
12-27-2018 21:56
As I understand it, the Web API works essentially the same for all devices, although devices that don't have heart rate monitors (for example) don't tend to provide much of that sort of data. 🙂
The application you're probably referring to is here. I had to jump through that hoop for this, which might give you an idea of the authorisation flow and data quality (assuming you've got a Fitbit device to play with).
PS. I attended Monash several times during my PhD studies!
Best Answer12-27-2018 20:45
12-27-2018 20:45
If you're going to use Alta HR, you'll be needing the Fitbit 'web API'. That site describes the overall code flow and data availability. Note that security constraints require that the person to whom each watch is registered authorises you to get access to the data collected by their watch.
The resolution of data available is typically every 1 to 15 seconds.
Best Answer12-27-2018 21:19
12-27-2018 21:19
Thanks! Is this process different dependent on which tracker is used, or is it the same for all of them?
I also read that for researchers (vs individual users) to gain access to the raw data, we need to submit some kind of application. Where does that happen?
Best Answer12-27-2018 21:56
12-27-2018 21:56
Best Answer01-08-2019 15:21
01-08-2019 15:21
Again, thanks for this! This was very helpful and should get us started.
