Is it possible to integrate the percentage battery status of the charge 2 in the WEB API.
At the moment the API show low etc.
I`ll find it will be useful to return the percentage number.
Get Devices
"battery": "High",
"batteryperc": "95%",
@pe_Mani_rl Probably, but the Fitbit app & devices would have to start using/displaying battery percentage first before that would happen.
Best AnswerAnd how can you retrieve the data battery status "High" ?
@pe_Mani_rl With the devices endpoint. I'm not sure what the threshold is for the battery status "High", but you can probably assume it means the battery level is 3/4 or above.
