In iOS when we deploy our application using Fitbit API, it's saying that please share the proof that FitBit is authorized to take Heart Rate information from patient.
Please help me out as how we can have this doc which states that Fitbit is legally authorized to manage the heart rate information of a customer
Best AnswerAre you using the SDK (eg, device API) or Web API?
Best AnswerGotcha. This forum will probably get you better responses. Re "it's saying", it might be helpful if you could clarify exactly what program/app/site is saying that.
Hi @Robin_123
Can you describe to me what your application does? Is it used for medical research? Also, do you have a Terms of Service and Privacy Policy that explains the reason for collecting the Fitbit data and how it is being used? Because, the request posted by Apple doesn't specifically state that Fitbit needs to provide you this information. Instead, it sounds like they are asking for information from an IRB review board. And, it sounds like they think Fitbit is a medical device when it is actually a fitness tracker.
Gordon
Hi @Robin_123
Did you describe the Fitbit device to Apple as "external medical hardware to provide medical services."? If so, that might be where the issue is. Our device is not medical hardware. It is a consumer activity tracker. I have not heard that we have have submitted our "device" to a regulatory organization to be cleared as medical hardware. We have submitted some algorithms to the FDA for approval, but that different. You can read about our FDA approved features here: https://healthsolutions.fitbit.com/providers/.
If you did describe the Fitbit devices as "external medical hardware", then you will need to correct your description with Apple.
Gordon
Best AnswerHello Gordon,
Greetings for the day!
Can you please provide sample code for PHP Web API because I am not getting access_token properly via web API.
Hi @Robin_123
The only sample code I have is in our documentation: https://dev.fitbit.com/build/reference/web-api/developer-guide/libraries-and-sample-code/#Sample-Cod.... You could try some internet searches to see if you can find others. Searching google for "php fitbit code" a bunch were returned.
Gordon
Hello Team,
Have a nice day!!
Lastly, how can we create the capability to connect to lights (Other IOT)? Are we considering via Fitbit watch? Please let me know
Best AnswerHi Team,
I have some queries related to API access: -
Can you describe what IOT support are you looking for out of Fitbit? Are you looking for the lights to turn on/off when you reach a fitness goal, or just the ability to adjust a light on the device?
