In the fitbit API document, it says that for "Implicit grant flow", you can "Pre-select the desired access token lifetime" by using 'expires_in'.
The response_type I am sending is "token" to specify it is implicit grant flow.
The expires_in I am sending is "2592000".
However, in the authorization page the expiration for the token is preselected to 1 day instead of 1 year.
In authroization page it says,
"Lift by McMaster University would like the ability to access the following data in your Fitbit account. for 1 day"
Please help on how to change this to 1 day to
I do see a typo with the parameter name. Try changing "expired_in" to "expires_in" to see if that helps.
Gordon
Hi @amitbinu51
Would you please post your authorization URL and obfuscate the values for client_id and redirect_uri for me? I'd like to see the complete URL and their values which a participant would select to display the consent webform.
Thanks!
Gordon
Gordon
oops. Didn't see that. It works now.
Thanks a lot!
