12-16-2021 10:26
12-16-2021 10:26
Hi, I am trying to build a webapp using integromat but am stuck on Oauth2 verification, I am getting
"errors":[{"errorType":"invalid_client","message":"Invalid authorization header format."
every time I try and connect using the HTTPs module. Any idea what commonly causes this?
12-16-2021 11:35
12-16-2021 11:35
Hi @BlueDev
The error sounds like a syntax problem. Have you checked out the examples for the specific endpoint that is returning the error? If you've double-check the syntax, then please private message me the endpoint and headers you're trying to execute.
Gordon
Best Answer07-08-2022 12:13
07-08-2022 12:13
@BlueDev Did you ever figure out how to connect Fitbit to Integromat? I am having a tough time figuring it out!
