05-04-2016 04:32
05-04-2016 04:32
Hi,
I'm developing an app to get fitbit information.
And i have a problem. That is why i'm here. I want first step login on my website with local login or social networks. And then with fitbit.
i show you the error:
GET /auth/fitbit/callback?code= - - ms - -
InternalOAuthError: Failed to obtain access token (status: 400 data: {"errors":[{"errorType":"invalid_grant","message":"Authorization code invalid: Visit https://dev.fitbit.com/docs/oauth2 for more information on the Fitbit Web API authorization process."}],"success":false})
at Strategy.OAuth2Strategy._createOAuthError (/home/usuario/easy-node-authentication-master/node_modules/passport-oauth2/lib/strategy.js:370:17)
at /home/usuario/easy-node-authentication-master/node_modules/passport-oauth2/lib/strategy.js:166:45
at /home/usuario/easy-node-authentication-master/node_modules/oauth/lib/oauth2.js:177:18
at passBackControl (/home/usuario/easy-node-authentication-master/node_modules/oauth/lib/oauth2.js:123:9)
at IncomingMessage.<anonymous> (/home/usuario/easy-node-authentication-master/node_modules/oauth/lib/oauth2.js:143:7)
at IncomingMessage.emit (events.js:117:20)
at _stream_readable.js:944:16
at process._tickCallback (node.js:458:13)
GET /auth/fitbit/callback?code= 500 501.697 ms - 1088
server.js
passport.use("fitbit",new FitbitStrategy({
clientID: config.fitbitClientId,
clientSecret: config.fitbitClientSecret,
scope: config.fitbitScope,
callbackURL: config.fitbitCallbackURL
function(req, token, tokenSecret, profile, done) {
// asynchronous
process.nextTick(function() {
// check if the user is already logged in
if (!req.user) {
UserFit.findOne({ fitbitId: profile.id }, function(err, user) {
if (err)
return done(err);
if (user) {
// if there is a user id already but no token (user was linked at one point and then removed)
if (!profile.refreshToken) {
profile.refreshToken = refreshToken;
user.save(function(err) {
if (err)
return done(err);
return done(null, user);
return done(null, user); // user found, return that user
} else {
// if there is no user, create them
user = UserFit.fromFitbitProfile(profile);
console.log('Creating user account for ' + profile.id);
//modificado update por save
UserFit.update(function(err) {
if (err)
return done(err);
return done(null, UserFit);
UserFit.js
var mongoose = require("mongoose");
var UserFit = mongoose.model("UserFit", {
refreshToken: String,
aboutMe: String,
age: Number,
avatar: String,
aveargeDailySteps: Number,
dateOfBirth: Date,
displayName: String,
fullName: String,
distanceUnit: String,
fitbitId: String,
gender: String,
glucoseUnit: String,
height: Number,
heightUnit: String,
locale: String,
weight: Number,
weightUnit: String,
timezone: String,
country: String
UserFit.fromFitbitProfile = function(profile) {
var data = profile._json.user;
console.log(profile);
console.log(data);
return new UserFit({
refreshToken: profile.refreshToken,
aboutMe: data.aboutMe,
age: data.age,
avatar: data.avatar,
aveargeDailySteps: data.aveargeDailySteps,
dateOfBirth: data.dateOfBirth,
displayName: profile.displayName,
fullName: data.fullName,
distanceUnit: data.distanceUnit,
fitbitId: profile.id,
gender: data.gender,
glucoseUnit: data.glucoseUnit,
height: data.height,
heightUnit: data.heightUnit,
locale: data.locale,
weight: data.weight,
weightUnit: data.weightUnit,
timezone: data.timezone,
country: data.country
module.exports = UserFit;
Best Answer05-04-2016 13:00
05-04-2016 13:00
Hi @JavierJavier, we can't debug your code, but we're happy to debug your HTTP requests and responses. Please try to capture the requests and share here (remember to obfuscate your Auth header). You can use a tool like Runscope Traffice Inspector to do this.
Given the error 'data' you posted, it looks like your app is not passing the 'code' value correctly.
