01-07-2017 15:26
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
01-07-2017 15:26
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
First off I have to say the documentation is a bit dissapointing, having a full example of the http request examples would help a ton. Second the documentation for logging activities doesn't work for me
This is the payload copy pasted from here https://dev.fitbit.com/docs/activity/#activity-logging
{ "activityLog":{ "activityId":12030, "activityParentId":90009, "calories":197, "description":"5 mph (12 min/mile)", "distance":3.34, "duration":1800000, "isFavorite":false, "logId":132394, "name":"Running", "startTime":"12:20", "steps":2970 } }
Sending this request from fiddler results in a 400 with error message of
{"errors":[{"errorType":"request","fieldName":"n/a","message":"Either \"activityId\" or \"activityName\" should be present"}]}
Clearly activityId is set. I've tried modifying this example for just adding a simple walk activity using all sorts of combinations of the walking activityId and activityName but I always get this error message.
In testing I also found out that sending bad json also results in this error message instead of informing the user that the json post payload isn't valid which would be very helpful.
Any ideas on what I'm doing wrong here?
Also could someone update the documentation to be correct? At least one required field (Date) for Logging an activity is different from the ones listed in the example.
(these parameters should correspond to the json blob above.
POST Parameters
activityId | optional/required | This is the Activity ID of the activity, directory activity, or intensity level activity. If you pass directory activity id, Fitbit calculates and substitutes it with the corresponding intensity level activity id based on the specified distance and/or duration. |
activityName | optional/required | Custom activity name. Either activityId or activityName must be provided. |
manualCalories | optional/required | Calories burned, specified manually. Required with activityName parameter, otherwise optional. |
startTime | required | Activity start time. Hours and minutes in the format HH:mm:ss. |
durationMillis | required | Duration in milliseconds. |
date | required | Log entry date; in the format yyyy-MM-dd. |
distance | optional/required | Distance; required for logging directory activity. In the format X.XX and in the selected distanceUnit or in the unit system that corresponds to the Accept-Language header provided. |
distanceUnit | optional | Distance measurement unit. Steps units are available only for "Walking" (activityId=90013) and "Running" (activityId=90009) directory activities and their intensity levels. |
Thanks,
John
01-10-2017 15:11 - edited 01-10-2017 15:12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Who Voted for this post?
@programit What's the request that you're making?
Here's an example:
https://api.fitbit.com/1/user/-/activities.json?activityId=90009&startTime=12%3A20&durationMillis=600000&date=today&distance=3.3
Gives me this response:
HTTP/1.1 200 OK Content-Language: en Cache-control: no-cache, private Fitbit-Rate-Limit-Limit: 150 Connection: keep-alive Server: cloudflare-nginx X-Frame-Options: SAMEORIGIN Date: Tue, 10 Jan 2017 23:09:39 GMT Transfer-Encoding: chunked Vary: Accept-Encoding Fitbit-Rate-Limit-Remaining: 150 CF-RAY: 31f3cc3ffabb239c-IAD Fitbit-Rate-Limit-Reset: 3021 Content-Type: application/json;charset=UTF-8 { "activityLog": { "activityId": 90009, "activityParentId": 90009, "activityParentName": "Run", "calories": 201, "description": "Running - 5 mph (12 min/mile)", "distance": 3.299999, "duration": 600000, "hasStartTime": true, "isFavorite": false, "lastModified": "2017-01-10T23:04:38.585Z", "logId": 5510346712, "name": "Run", "startDate": "2017-01-10", "startTime": "12:20", "steps": 3737 } }
