I understood the default value for token expires_in is 8hrs.
What are the other supported values for expires_in ?
Is it possible to set values less than 8hrs, as I want to test the refresh token mechanism incase of access token expired ?
Thanks
Hi @sanmitha,
The token duration for an access_token under the authorization code grant flow is a non-negotiable 8 hours.
If you are using the implicit grant flow (not recommended), then you can set the expires_in value up to a year (in seconds), but as mentioned, this flow is not recommended due to its security vulnerabilities.
