I having a LOT of problems trying to use Fitbit python to access my data on the web.
I have tried registering my App and getting ClientID and Client Secret and a callback to my website. Not sure if I should be specifying Client or Personal
I tried to use
And this opens my home page with the following added to the URL.
#access_token=XXXXX&user_id=YYYYY&scope=heartrate+activity+weight&token_type=Bearer&expires_in=604800
From documentation and examples on the web, I was expecting an Authorisation key and not an access token. I was expecting to have to use the supplied Authorisation key to get an access token and refresh token
The example python programs that access data seem to expect an access key and also a refresh token and I only seem to have an access token.
Yours extremely frustrated,
Hi @KeithSloan,
If you're just accessing your own data, then I would recommend using the "personal" application type in your application settings. Your application needs to use the authorization code grant flow in order to receive an authorization code that you exchange for the access and refresh tokens. This includes adding "response_type=code" in your authorize URL. Here's an example of what that authorize URL would look like
