Hi,
Push Notification using https generate response code SSLHandshakeException.
Any help solving this issue will be appreciated.
Thank you
This is console output from "curl -v https://xxx.yyy.com/fitbit/echo":
:~ test$ curl -v https://xxx.yyy.com/fitbit/echo
* Adding handle: conn: 0x7fbe92804400
* Adding handle: send: 0
* Adding handle: recv: 0
* Curl_addHandleToPipeline: length: 1
* - Conn 0 (0x7fbe92804400) send_pipe: 1, recv_pipe: 0
* About to connect() to xxx.yyy.com port 443 (#0)
* Trying XXX.XXX.XXX.XXX...
* Connected to xxx.yyy.com (XXX.XXX.XXX.XXX) port 443 (#0)
* TLS 1.0 connection using TLS_RSA_WITH_AES_128_CBC_SHA
* Server certificate: xxx.yyy.com
* Server certificate: Go Daddy Secure Certificate Authority - G2
* Server certificate: Go Daddy Root Certificate Authority - G2
> GET /fitbit/echo HTTP/1.1
> User-Agent: curl/7.30.0
> Host: xxx.yyy.com
> Accept: */*
< HTTP/1.1 200 OK
< X-Powered-By: Express
< Content-Type: text/html; charset=utf-8
< Content-Length: 155
< ETag: "59331560"
< Date: Wed, 27 May 2015 15:28:13 GMT
< Connection: keep-alive
* Connection #0 to host xxx.yyy.com left intact
Go Daddy Root Certificate Authority - G2 has issues. See https://community.fitbit.com/t5/Web-API/Why-am-I-seeing-SSLPeerUnverifiedException-errors-in-my/m-p/...
