I'm trying to get FB oauth running in an iOS app. I'm able to successfully make the request_token and access_token calls, but subsequent attempts to actually post data always fail with an invalid_sigature error.
Here's the error:
{"errors":[{"errorType":"oauth","fieldName":"oauth_signature","message":"Invalid signature: bmOOtH3Rb4Uoi66yE9V6fM0GjJc="}],"success":false}
from this call:
oauth_consumer_key: [##-this-is-my-consumer-key-##]
oauth_nonce: 650493950
oauth_signature_method: HMAC-SHA1
oauth_timestamp: 1403489016
oauth_token: 919a148254e19383842eba8545b24f9a
oauth_version: 1.0
Result: POST&https%3A%2F%2Fapi.fitbit.com%2F1%2Fuser%2F-%2Factivities.json&oauth_consumer_key%3D [##-this-is-my-consumer-key-##]%26oauth_nonce%3D650493950%26oauth_signature_method%3DHMAC-SHA1%26oauth_timestamp%3D1403489016%26oauth_token%3D919a148254e19383842eba8545b24f9a%26oauth_version%3D1.0
Encoded: bmOOtH3Rb4Uoi66yE9V6fM0GjJc=
Here are the ways I'm generating the various signatures (note that these are from a different run of the app than what's above):
Token Request:
oauth_nonce: 1112251665
oauth_timestamp: 1403488515
oauth_version: 1.0
Result: POST&https%3A%2F%2Fapi.fitbit.com%2Foauth%2Frequest_token&oauth_consumer_key%3D[##-this-is-my-consumer-key-##]%26oauth_nonce%3D1112251665%26oauth_signature_method%3DHMAC-SHA1%26oauth_timestamp%3D1403488515%26oauth_version%3D1.0
Encoded: bsEhI93QxUw0DkMACH5/ApWKLCk=
Access Request:
oauth_nonce: 607151652
oauth_timestamp: 1403488538
oauth_token: 889d83911124adba5420ec4f51ad738b
oauth_verifier: lc50p7jhhgea1if0hukj4saqso
oauth_version: 1.0
Result: POST&https%3A%2F%2Fapi.fitbit.com%2Foauth%2Faccess_token&oauth_consumer_key%3D[##-this-is-my-consumer-key-##]%26oauth_nonce%3D607151652%26oauth_signature_method%3DHMAC-SHA1%26oauth_timestamp%3D1403488538%26oauth_token%3D889d83911124adba5420ec4f51ad738b%26oauth_verifier%3Dlc50p7jhhgea1if0hukj4saqso%26oauth_version%3D1.0
Encoded: Vifsf1QCIyZ25uk7sN8le3UEp98=
POST request:
oauth_nonce: 714024649
oauth_token: a4e03XXXac494398962b3952a152d7c6
oauth_version: 1.0
Result: POST&https%3A%2F%2Fapi.fitbit.com%2F1%2Fuser%2F-%2Factivities.json&oauth_consumer_key%3D[##-this-is-my-consumer-key-##]%26oauth_nonce%3D714024649%26oauth_signature_method%3DHMAC-SHA1%26oauth_timestamp%3D1403488538%26oauth_token%3Da4e0393bac494398962b1895a152d7c6%26oauth_version%3D1.0
Encoded: zBJo00xzmmpwjvGmFiRk7JmekVA=
Am I missing something obvious here?
Thanks!
Ben
Ben.
Can you please explain what are trying to do with request you're making?
Seems that you trying to post an activity how ever you don't pass any parameters to post.
If you want to read data then you have to use GET instead of POST.
Please check here for examles for possible requests: https://wiki.fitbit.com/display/API/API+Explorer
Also beware, once you've got issued an access token make sure you save it somewhere so you can pull it out later. If you request a new access token, previous one will be invalidated.
Best AnswerI'm trying to post an activity (steps, to be exact). Here's the full URL I'm using:
I'm caching the request token, the reason there are repeated token requests in the sample is that I'm trying to figure this problem out, so I keep wiping out my saved data :-)
Thanks!
Ben
from this call:
oauth_version: 1.0
Factivities.json&oauth_consumer_key%3D [##-this-is-my-consumer-key-##]%26oauth_nonce%3D650493950%26oauth_signature_metho d%3DHMAC-SHA1%26oauth_timestamp%3D1403489016%26oau th_token%3D919a148254e19383842eba8545b24f9a%26oauth_version%3D1.0 Encoded: bmOOtH3Rb4Uoi66yE9V6fM0GjJc=
I could not find a user with the token "919a148254e19383842eba8545b24f9a"
What do you mean by caching the request token? The request token can only be used to get an access token and once you get the access token, it should be discarded.
Best AnswerSorry, I mispoke, I'm caching the access_token (returned from the /access_token call as the oauth_token field. I just re-did my auth, and my current access token is "7cab53e8f2f6d1d2842e4691490b49a7"
This token does not exissts in our system too.
How are you getting the access token? Is it steps D-E: https://wiki.fitbit.com/display/API/OAuth+Authentication+in+the+Fitbit+API#OAuthAuthenticationintheF... ?
Best AnswerThe access_token is returned after I make call "E", (the server response is then "F"). The first message in the thread shows the order of calls I make, I just changed the paramters a bit to protect my keys.
Ah, nevermind I see your token now...
Can you please send me in a private message the request that you're making so I can validate that the signature you're generating is correct.
