Two questions, really:
1) I noticed that the Fitbit app has settings that allow you to set an alarm for when you want to go to sleep. Is this available via the API? I don't see it under the 'Sleep Goals' section of the API, which I thought was the most logical place.
2) I really like the new 'Get Activities Logs List' endpoint, especially for the SmartTrack activities. Is there a way to tell what settings the user has set for SmartTrack activities? For example, if the user sets the 'Walk' detection to only detect walks greater than 30 minutes, is there an endpoint in the API that allows us to get this information? Or will there be? Basically, we would use it for normalization across users.
Thanks!
@rMirage Currently going to say no to both, but I think that would be useful information to pull. Thanks for bringing it up.
