The subscription verification for our application is failing and showing this message "Subscriber has not been successfully verified."
The endpoint is working fine and it is returning the correct 204/404 replies when the code is either correct or invalid.
I tried hitting the verify button several times but the subscription is not getting verified.
Oauth client id: 22C4VD
What i'm doing wrong ?
This is critical for us. Please look into it asap.
Thanks in advance.
Hi @changhc
Once your subscriber is verified, you'll reference the subscriber ID when adding a subscription. See https://dev.fitbit.com/build/reference/web-api/subscriptions/#adding-a-subscription. If your application has multiple subscribers, referencing the subscriber ID when adding the subscription let's Fitbit know which subscriber to send the notification.
Gordon
Hi @changhc
In our logs I see your subscriber is sending a 404 when we send you the correct verification code. You should be replying with a 204. Would you please verify this in your code?
Gordon
Hi @Gordon
I checked the log and found a value other than the Subscriber ID set by the verification code, so I modified it and processed it.
Where do I use the Subscriber ID I set ?
Hi @changhc
Gordon
