Hi everyone.
I have purchased FitBit Inspire 3 to be used in a personal/university project of mine.
The goal, as mentioned in the title is to track calories burned during exercise.
After I complete an exercise and it appears on my FitBit dashboard, when I click on it, I see the following chart, which is exactly what I want to recreate using either exported data from FitBit or a response from an API endpoint.
In this chart we see cals/min values on a per second basis.
I have tried to export FitBit data through Google Takeout, and also export the exercise in TCX format. No such data available, not that I could find at least.
Browsing through the API, I believe the most relevant endpoint for my query would be "Get Activity Intraday by Interval", but from what I see in the Documentation, that would at best take me to minute-level data, not second-level, as we see in the chart in the dashboard.
So, to wrap this up, the short question is, how would one go about recreating a chart as the one above?
Many thanks!
Hi @fitburner
You are correct that the Activity Intraday endpoint will provide you with the calories / min data to recreate the chart. If you notice in the chart, the calories burned over a period of a single minute stays constant. The slider bar is showing seconds but the data over a single minute is still constant. Calories / second is not available. If calories / second were available, you would see the calories burned change over the length of a single minute.
Best,
Gordon
Best AnswerHi @Gordon-C ,
Many thanks for the quick response.
I've played around a bit with the particular API endpoint, and indeed, I can recreate the chart as envisioned.
I have another question, for which I suspect what the correct answer is, but also wanted to ask your for confirmation.
Lets say that among all other datapoints, I get the following (it's not actual data, I just use random values):
time: 16:41:00, value (calories): 10.57897 (lets call this number A)
The question is, does number A correspond to calories burnt from 16:40:01 to 16:41:00 or from 16:41:00 to 16:41:59?
Many thanks for your consideration
Hi @fitburner
From what I can tell, it looks like the calorie burn value comes from the previous period. So, in your example 10.57897 calories were burned from 16:40:01 - 16:41:00.
Gordon
