POST https://api.fitbit.com/1/user/7JN333/devices/tracker/817030095/alarms.json?time=17:45-5:00&enabled=true&recurring=false&weekDays=SATURDAY
Authorization: Bearer ***
An error occurred with the Fitbit Web API while processing the request. Error id: 0242f6fffec9744c-002aef50-0ee4b4d7-7599a2ad930156a0-44ad1652-15
https://dev.fitbit.com/build/reference/web-api/troubleshooting-guide/error-messages/
500 Internal Server Error:
| An error occurred with the Fitbit Web API while processing the request. | Try your request later. |
I've tried it several times over the past several minutes to no avail... Can the error be more detailed? I have no idea if I'm doing something wrong (new to your API so that's entirely possible), or if this is exclusively a problem with your server.
It looks like the UTC offset in your "time=" parameter is missing a 0. Please try again using the HH:MM formatting. In this case, it should look like this :
time=17:45-05:00
Let me know if this helps!
time=17:45-05:00
Oh god I'm so embarrassed. Thank you John. 😃
