01-05-2018 15:09
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
01-05-2018 15:09
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Hello,
I am looking at my own Fitbit data and I see a discrepancy between the csv data extract and the data I pull via the .sleep or .get_sleep (they give me the same exact result) python libraries, for data on the same day.
For instance below are some parameters I extracted from the Fitbit API:
endTime = 2018-01-04T06:42:00.000
startTime = 2018-01-03T23:49:30.000
'stages': {'deep': 27, 'light': 152, 'rem': 39, 'wake': 48},
'totalMinutesAsleep': 387,
'totalSleepRecords': 1,
'totalTimeInBed': 412
awakeningsCount = 12
While below are the same parameters taken from the csv extract, which matches what's on my phone app:
Start Time | End Time | Minutes Asleep | Minutes Awake | Number of Awakenings | Time in Bed | Minutes REM Sleep | Minutes Light Sleep | Minutes Deep Sleep |
2018-01-03 11:49PM | 2018-01-04 6:42AM | 358 | 54 | 21 | 412 | 98 | 203 | 57 |
The Time in Bed is the same, but all other quantities differ.
Any insights would be much appreciated!
Thanks!
01-15-2018 19:03
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
01-15-2018 19:03
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
How did you get Fitbit to export a CSV instead of a JSON from the web API?
01-16-2018 07:25
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
01-16-2018 07:25
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Hello,
you can export a CSV from your account by clicking on the Gear --> Settings --> Data Export. There you have the option to select CSV as file format.
On a different note, I found the solution to my question.
To have a agreement between the two calls I had to modify two variables in the fitbit/api.py file:
API_ENDPOINT and API_VERSION.
