06-11-2017
14:51
20:07
LucyAP
06-11-2017
14:51
20:07
LucyAP
In addition to the above the slot on the back which you have to turn to change the battery is now breaking due to constantly being opened and closed. I don't think it will be able to be opened any more as so much of the plastic has now worn away.
Moderator edit: title for clarity
06-12-2017 20:01
06-12-2017 20:01
Thanks for stopping by @JudeC! I think that restarting and checking the inside spring can be of help. Also, please try these tips to fix your syncing issues.
Keep me posted! 😉
06-22-2017 10:53
06-22-2017 10:53
Lucy - the fitbit no longer opens as the plastic cover has worn away around the battery slot due to having to change the battery so many times. The time varies - it is now 7:08 on the fitbit (actual time is 18:52) but sometimes it is only an hour or two wrong. No syncing for well over a week.
But once the current battery runs out I won't be able to use it as I can no longer open the back.
Best Answer06-22-2017 11:04
06-22-2017 11:04
My Fitbit zip was a gift two years ago and has had two new batteries. It now won't work and since the last battery change, it has only synced intermittently.
I am very upset about this and would like some answers.
06-22-2017 19:10
06-22-2017 19:10
Thanks for your reply @JudeC! I really appreciate the effort you have made to solve this. To further assist you, I've created a Support Case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums.
@Jacqueline_ Welcome to the forums! Can you please confirm that you have tried my suggestions above? I'd love to help you get back on track.
Let me know the outcome! 😉
Best Answer10-11-2017 22:16
10-11-2017 22:16
Hi Lucy, sorry for the delay in replying. I have tried everything you suggested but still no joy. Where do I go from here? My daughter also has a Fitbit zip and has no problems with it at all, and it's older than mine.
Jacqueline
Best Answer10-12-2017 19:52 - edited 10-12-2017 20:02
Thanks for posting back @Jacqueline_! I really appreciate the time and effort invested to solve this. To better assist you, I've created a Support Case on your behalf - you should receive an email from Customer Support (it'll be sent to the email used to register to the Community forums).
Catch you later!
P.S. While you wait for Support, please take a look to our Warranty Policies.
