01-20-2019
18:05
06:47
YojanaFitbit
01-20-2019
18:05
06:47
YojanaFitbit
With the Zip, can you see the route you walked on the software or do you just get distance and steps?
Moderator edit: Updated subject for clarity.
01-21-2019 06:40 - edited 01-21-2019 06:42
Hi @Cynfranks, nice to see you on the Fitbit Forums.
You have a great questions there! Fitbit Zip will track and display the following:
• Steps taken
• Calories burned
• Distance traveled
• A clock
• The Fitbit Smiley, which highlights your recent activity level
Only trackers or watches with GPS or Connected GPS will show you the route or map on the Fitbit app after you synchronize your information, in this case with Fitbit Zip you get the same stats that I mentioned above on the Fitbit Dashboard in your phone/computer. You can find more information about Fitbit Zip on the manual.
Please check the features of the different Fitbit devices here: Find the product that’s right for you.
Hope this helps.
Best Answer01-21-2019 06:40 - edited 01-21-2019 06:42
• Steps taken
• Calories burned
• Distance traveled
• A clock
Hope this helps.
Best Answer01-23-2019 05:40
01-23-2019 05:40
Thank you. This is what I suspected.
I've been looking for a tracker that will show me my dog's route, and so far other than high-end hunting tracking systems, I have not found one.
Best Answer01-25-2019 10:00
01-25-2019 10:00
I apologize for the delayed response and thank you for your feedback @Cynfranks.
At this time is not possible to show your dog's route with Fitbit Zip.
Keep on visiting the forums.
