09-11-2018
18:18
05:32
YojanaFitbit
09-11-2018
18:18
05:32
YojanaFitbit
My Zip has had trouble syncing for a few weeks, it keeps saying "Tracker not found." I've tried taking the battery out and putting it back in after 10 seconds, sometimes that works but sometimes not. I just changed the battery 2 days ago and still getting the same message. Help!
Moderator edit: Updated subject for clarity.
Hi @Liquidpixie, it's nice to have here, welcome!
Thanks for all the steps that you've tried. If those recommendations don't work let's check some requirements that your phone and Zip should have in order to successfully communicate:
Requirements:
If the syncing issue remains with a mobile device I would recommend following the steps below:
Hope this helps and welcome again!
I finally got around to trying all these suggestions, and still nothing. The only thing that seems to work at all is taking the battery out and putting it back in, but I shouldn't have to do that every time I want to sync it.
Hi @Liquidpixiej, thanks for trying those steps. You're right, you shouldn't be resetting your Fitbit every time that you would like to connect it with the Fitbit App. What phone are you using? Have you checked these information: Why won't my Fitbit device sync?
Keep me posted.
Are you using the device with an Android phone by any chance? Android 9.0 to be specific?
Several people have this issue after the Android 9.0 update.
https://community.fitbit.com/t5/Android-App/Android-9-0-Pie-not-able-to-sync/m-p/2969503#M87926
Yes, that's actually exactly what I'm using. I don't know if the issue started before or after the update, but I'll check out that post, thanks! Nothing has worked so far and I think I've now tried everything suggested- very frustrating!
@Liquidpixie wrote:Yes, that's actually exactly what I'm using. I don't know if the issue started before or after the update, but I'll check out that post, thanks! Nothing has worked so far and I think I've now tried everything suggested- very frustrating!
Well then welcome to the party 😄 My Zip stopped syncing with my Google Pixel since the 9.0 update and I don't see a fix coming anytime soon, it has been over a month already !
Oh seriously?? It's been over a month for me now, too, so maybe that's what it was. Is it just the Zip, or other Fitbits? Because I don't want to wear one on my wrist!
Hi @RKLVV and @Liquidpixie nice to see you around.
Thanks for all the troubleshooting steps that you've followed until now. If you already tried the steps listed here. I'd suggest checking a different syncing device, maybe a computer or smartphone, to make sure that is not your Fitbit tracker the one that is not longer responding. If that's the case I'll be more than glad to request a case for you, if you need it.
About your inquiries regarding to syncing difficulties that some users have been reporting after updating to Pie, please check this information given by @AlessFitbit. You can add your questions to this two threads if wish.
Keep me posted.
Hi @YojanaFitbit, Yes, I've tried all the troubleshooting steps listed and several others too. I could use my computer or an older smartphone to sync, but I usually don't use my personal computer everyday. That's fine though, I am now using an alternate device/service to track my activity.
But @AlessFitbit did provide an update on the other discussion thread, will just wait for the fix now. Hopefully that will be soon.
Exactly @RKLVV, I saw that information. Thanks for getting though, we all are waiting for more information about it. But I'm sure she will post any update as soon as she gets it. Thanks for trying a different syncing device. I hope this gets resolve soon too.
Have a good one!
09:43
13:03
YojanaFitbit
01-05-2019
09:43
13:03
YojanaFitbit
I posted back in September that my Zip was not syncing with my phone (Pixel), and I tried all the suggestions given to me then by a moderator but nothing has worked other than taking the battery out and putting it back in. I know others had this issue, and I'm wondering if it has been fixed yet. I do have the opportunity to get a new Zip, if I wouldn't have the same problem with a new one.
01-05-2019 12:09
I made that last comment as a separate post, so why did it get added to this post?
Thanks for getting back @Liquidpixie. Thanks for following the suggested steps.
Sorry for the time I took to respond. Syncing difficulty is usually caused by a missing requirement. Verify each requirement before moving on to the troubleshooting steps.
Depending your phone, these tips might make syncing easier:
If your Fitbit device still won't sync, try these steps:
Please confirm what mobile device you are using. About your post, please check your Private Message inbox. Let me know if you have questions.
See you around.
Best Answer@YojanaFitbit@ I tried every one of those steps back in September and it still didn'
work. I decided to just replace my Zip and it arrived in the mail today, so
I got it all set up and I'm STILL seeing the message "tracker not found."
Do I seriously need to go through all those steps again with my brand new
Zip? What is going on here?
Thank you for getting back to us and for following the advised steps with your new Zip @Liquidpixie. I apologize for the delayed response and will be glad to assist you.
Could you please check and confirm that you have the latest Fitbit App version on your phone.
Thank you for your patience and for visiting the forums.
Best Answer@AndreaFitbit I assume it's the most recent version, because as I said, I did all the suggestions and one of them was to uninstall and reinstall the app, and it was the only version that came up in the play store. I just checked and it says 2.84.
Thank you for getting back to us @Liquidpixie. I apologize for the delayed response and will be glad to continue assisting you. Thank you for following the suggested advise and for letting us know about your current app version.
In order to better assist you could you please let me know if you have tried to sync your Zip with a different device. Please let me know and I'll continue helping you out.
Thank you for visiting the forums.
Best Answer@AndreaFitbit if by another device you mean a computer, then no because I only have my phone to use, and that's all I should need. That is literally the only thing I haven't tried that had been suggested, and nothing works other than taking the battery out and putting it back in. I'm telling you this so that you don't need to ask me about each individual thing in that list that the moderators suggest. I just want to know if this is going to be fixed and when, because lots of people have been having this same problem for months.
Thanks for getting back @Liquidpixie!
Thanks for confirming that information. I've requested a case for you, our team will be contacting you via email shortly to give you a hand with this. Fitbit has been designed to provide motivation and help you to reach your daily goals to success.
Let me know if you have questions about it.
