04-06-2016 14:40
04-06-2016 14:40
Best Answer04-07-2016 04:47
04-07-2016 04:47
Hello @Kellitrippzach and welcome aboard to our community. Note the time and date on your tracker is managed by your timezone settings on your Dashboard.
1. Log into your fitbit.com dashboard and click the gear icon in the top right corner.
(Or you can use the hyperlink above)
2. Select “Settings” from the drop-down menu.
3. Scroll down to the Time section and choose the time zone that best reflects your current location. You can also select 12-hour or 24-hour time display format here.
4. Sync your tracker to update your time zone.
Hope this helps and keep me posted if you need some help.
