03-30-2016 09:45
03-30-2016 09:45
If I replace my battery before I sync to my computer will I lose the data that has not been sycned? Some devices will "hold" just enough power for people to quick switch out the batteries.
I can't get my Zip to sync and I think it's because the battery is too low. I also don't want to lose the data from the last 24 hours by changing the battery.
Best Answer03-30-2016 10:18
03-30-2016 10:18
I've never lost data after changing the battery. I was worried about the same thing, but it stores it and waits to sync until you stick a new battery in. It's fine. 🙂
12:01
07:47
04-06-2016
12:01
07:47
Hi @ClaraI91, welcome to the Forums! You don't have to worry, if you take out the battery, your data won't be touched even if you don't sync before that, as @SunsetRunner mentioned.
So now, can you please tell me if your Zip still not syncing? If that is the case, could you please take a look of this post? It has instructions to help you out syncing your Zip.
Let me know how it goes! ![]()
