After some really humid days, there was some condensation inside my zip’s screen. It was hard to read the screen, but it still worked. Today, nothing. I tried a new battery, that didn’t help.
What should I try?
Best AnswerHi @johnsada
Try putting the Zip into a dry bowl of rice for two or more days to draw out the moisture. Then clean it out with alcohol on a cotton swab and see what a fresh battery will do.
Let us know what happens.
