09-23-2017
05:00
20:01
LucyAP
09-23-2017
05:00
20:01
LucyAP
My zip died! The battery was replaced a bit ago and was reading 1/2. I replaced the battery and still will not turn on...Help!
Moderator edit: title for clarity and format
Thanks for stopping by @Alistrina! This sounds odd. Please make sure that the battery was inserted into the back of the unit, with the “+” sign facing up. The battery will rest in the center of the compartment.
Also, double check that the inside metal spring is correctly aligned. You can follow here the process suggested by @vomitofthemind.
Keep me posted with the outcome! 🙂
Thank for your reply @Alistrina! Great to hear that you are back on track. Let me know If you need extra help with this.
You are welcome, it's always my pleasure! I'd like to encourage you to join us at Discussions board, there you can be inspired, find some tips to get moving, eat well, manage weight, sleep better, live mindfully and more!
Give it a look! 😉
