Hello @Nickyjoppa, thanks for joining us, it's great to have you on board! ![]()
Has the screen started dimming recently or is it an issue that has been present for a very long time? It's possible that you might need to change the battery. With normal use, the battery of the Zip lasts from 4 to 6 months. If the battery on your tracker is fairly new, my best recommendation would be restarting your tracker.
To restart your tracker:
In case you need to replace the battery, please open the battery door, remove the battery and place the new one. Remember that the Zip uses a 3V coin battery model CR2025.
I hope this can be helpful, give it a try and keep me posted! ![]()
