05-16-2016 00:15
05-16-2016 00:15
10:06
07:28
05-16-2016
10:06
07:28
Hey @Pauline1963_7 welcome to the Community!
don't worry. I'm pretty sure this can be fixed by restarting your Zip. Just follow the steps below:
1. Open the battery door using the battery door tool and remove the battery.
2. Wait 10 seconds.
3. Place the battery back into the tracker with the "+" side facing up, and close the door.
Also, please make sure you have the correct timezone setting on your Fitbit account.
Let me know if that helps!
Best Answer11-07-2020 14:13
11-07-2020 14:13
What battery door tool? Should it have come with the fitbit?
Best Answer12-27-2020 13:34
12-27-2020 13:34
Yes it comes with it.
