06-03-2017 18:20
06-03-2017 18:20
My FitBit Zip synced yesterday without any problem. I changed nothing.
Today it will not sync.
I use Bluetooth to sync via an app on my laptop. The device is paired in Bluetooth.
I have tried:
unpair device - remove battery - wait - reinsert battery - pair device in bluetooth - did not fix the problem
log out of the app that is installed on my laptop and then log back into the app -- did not fix the probelm
What can I do to resolve this?
Thanks!
Best Answer06-04-2017 18:25
06-04-2017 18:25
Thank you.
I added it as a new device and that seemed to work. It was able to sync.
Best Answer06-04-2017 19:13
06-04-2017 19:13
and you lose all the data that hasn't been sync'd
06-04-2017 19:29
06-04-2017 19:29
how do you unpair. I don't understand the pairing
06-05-2017 00:02
06-05-2017 00:02
Works for only once then back to won't sync This started after latest update on 3 June 2017
06-05-2017 03:57
06-05-2017 03:57
Lose the data? So I definitely need to get a screen shot for the Wellness program before trying much else???
Best Answer06-05-2017 07:22
06-05-2017 07:22
It has occurred to me that the sync problem may be network overload and not our devices. Maybe Fitbit's network isn't big enough to handle all the devices sync'ing and we only sync when we happen to catch a slower time
Best Answer06-05-2017 07:39
06-05-2017 07:39
The accepted solution isn't working. My FitBit was last able to sync last Saturday at 8:36pm. I have tried everything suggested (Bluetooth, remove device, add device, tried multiple times on multiple days), and even taking the battery out of my FitBit and putting it back in. Nothing has helped.
Any other suggestions?
06-05-2017 07:57
06-05-2017 07:57
@rustell wrote:
@rustell wrote:
@Kazimac wrote:
If you contact them its easily sorted. I followed their advice: Unpaired my zip, set up my zip as a,new device, bingo!!
Sent from my Windows 10 phoneThis worked... the key is to set it up as a new device... Thanks Kazimac
Well .... it worked once. The only way I can get mine to sync is to set it up as a new fit-bit.
After all this, I was still only able to sync by creating a "new" device every time I wanted to update my information. I ended up calling tech support and they had me doing everything we have covered here with the same results. The bottom line is that I need a new fit-bit and I am out of warranty. They did offer me 25% discount if I purchased from them. This device lasted 17 months.
06-05-2017 11:46
06-05-2017 11:46
I have tried everything mentioned in these posts and nothing works. I see so many complaints. Isn't it time Fitbit improved its products. I am exploring what's out there that is more reliable. It is difficult to put in the effort and unable to record it.
06-05-2017 15:30
06-05-2017 15:30
I had put my fitbit on table being that It would not sync this morning 6/5/ 2017. I just picked it up and tried to sync it worked just perfect tried it three more times perfect GO FIGURE
06-05-2017 17:52
06-05-2017 17:52
Thanks for your reply. I tried all the things others mentioned but it stii]ll not not sync. I took it out to Best Buy and they couln't sync it either. They think the problem is with the Fitbit. I bought a Garmin. Justhad it with that product.
06-05-2017 17:53
06-05-2017 17:53
Thanks for your ideas. I tried all the suggestions I saw. Wished they had worked for me.
06-06-2017 10:32
06-06-2017 10:32
Okay, I'm done. I tried to find an email to send these comments to Fitbit but Fitbit evidently doesn't have one. After 3 devices all of which had this sync problem, I will no longer be trying to sync or buying another device. Fitbit's answer has been "we'll replace it" but they have made no effort to fix the problem. The sad thing is that Fitbit devices seem to be the best of what is out there. but they aren't worth the hassle. I'll use the Zip as an expensive pedometer until it quits working but no more.
Best Answer06-06-2017 16:34
06-06-2017 16:34
and this evening it sync'd
Best Answer06-06-2017 16:36
06-06-2017 16:36
and captured the info from the last several days
Best Answer06-07-2017 02:33
06-07-2017 02:33
16:31
07:04
06-07-2017
16:31
07:04
Hi everyone,
I'm sorry to hear of all of your syncing issues, glad to hear some of you are syncing again. I'm hoping I may be able to help.
First, I suggest you make sure you are on the latest version of the app. In particular, we had a recent update to the Android app and two recent updates on the Windows 10 app.
Second, if you haven't already please review the following help page, Why won't my tracker sync?
Hoping you all get back on track soon.
Actively managing your weight? Find accountability buddies on the Manage Weight board
Best Answer06-07-2017 18:43
06-07-2017 18:43
I downloaded the app a couple of days after the latest update so I have the latest version but it updates when it feels like it or says it's paired to another device and can't download. there is not other device
Best Answer06-08-2017 06:33
06-08-2017 06:33
06-08-2017 06:33
