08-20-2019 17:15
08-20-2019 17:15
My Fitbit is marking my steps but my phone keeps telling me that my Fitbit can't be found could you help me.please
Best Answer08-21-2019 00:08
08-21-2019 00:08
The usual things to try when you get syncing / connection issues are:
If none of those ideas work for you then it’s probably best to contact customer support via: contact.fitbit.com
08-21-2019 00:08
Best Answer08-24-2019 11:44
08-24-2019 11:44
I did it all it still doesn't work
Best Answer08-24-2019 12:29
08-24-2019 12:29
Then it's time to contact customer support
Best Answer08-24-2019 13:48
08-24-2019 13:48
Best Answer08-24-2019 23:26
08-24-2019 23:26
Sorry to hear that. I guess that means you are no longer in warranty. If customer support can't help then I'm afraid that's the end of your fitbit.
Best Answer08-25-2019 04:28
08-25-2019 04:28
It is not a zip problem. It is a software problem that Support is ignoring. Fit bit zip is fine. Battery full. Worked Friday. Now app does not find zip. But works fine on laptop.
Best Answer08-25-2019 05:53
08-25-2019 05:53
Best Answer08-25-2019 12:38
08-25-2019 12:38
I don't think I should have to buy another one when I haven't had this one Fitbit Zip that long and having nothing but trouble with it I tried everything you ask of me and I still AM having nothing but trouble I should be eligible for a up graded on one I was looking at them and I seen one for a in expensive one I seen the one for only 2,500 points please consider it
Best Answer08-25-2019 12:54
08-25-2019 12:54
