Help - Notification of Low battery
I just bought my fitbit two days ago it's not been keeping up with the correct syncing and tonight I just got an email that my battery is low. Do the batteries run out that fast?
Moderator Edit: Updated Subject For Clarity
5 REPLIES 5
Welcome to the Community @MelissaT4! Oh! yous Zip is pretty new to giving you these issues. But don't worry, let me suggest you to replace the battery and verify that there is proper contact between the battery and the battery contacts inside your Zip tracker. You can do this by opening the battery door of your Zip, removing your battery, and ensuring that the silver battery tab located in the lower right half of your tracker is flush with the white box outline in the tracker housing. The process can be followed here: http://imgur.com/a/l1KwH
Now for the syncing issue, let me suggest you to follow the tips on @AlejandraFitbit post to fix that.
Let me know how it goes! Cat Happy
Heydy | Community Moderator, Fitbit
Find, rate and share the best memes and images. Discover the magic of the Internet at Imgur.
By the way I never said Thank u!
Hey @MelissaT4! Thanks for your reply! I appreciate you came back and let me know that your Zip is working now. Thanks for the update.
Keep me posted and have a great weekend!
Battery may have burned
Welcome to the Community @Cedrick! Let me help you out. Robot Very Happy What is the Fitbit that you are using? Can you please tell me the exact issue that you are having with your Fitbit?
Keep me posted!
