Hmm... @Fitletty I would try chatting with an agent. Do you know how to do that? If not, go talk with an agent. It could take a while to get on with an agent but its worth it. They are very thurough and will make sure they do the best they can. I hope you can figure it out!
@welkerville Thanks for sharing that tip!
@Fitletty Welcome to the Community! To edit your water log, I also recommend trying the following steps:
1. Open your Fitbit dashboard.
2. Tap on your "Water" tile.
3. Tap on the log you want to edit.
4. Tap on the number you want to edit. This should be located below "Log History".
5. Change this number to reflect the correct information.
I hope this helps! Let me know if you have any questions. ![]()
