07-13-2018
09:47
12:22
YojanaFitbit
07-13-2018
09:47
12:22
YojanaFitbit
I just put a new battery in and synced it.
The time is right but it shows data in each section, how do I clear it???
Thx!!!
Moderator edit: Updated subject for clarity.
07-20-2018 05:59
07-20-2018 05:59
Thanks for getting back! In this case I think that it's best to restart your Zip and keep an eye on it, since it looks like if the tracker had some syncing issues. It shouldn't be happening again but if it does, please keep me posted.
Thanks for your understanding. ![]()
Best Answer07-15-2018 12:21 - edited 07-15-2018 12:23
Hey there @Ksolomon! Welcome to the Family! ![]()
Good to hear that your Fitbit is working after you've changed the battery. Where exactly are you looking this data? As you mentioned that you can see stats in each section. Are you manually logging information on your Dashboard? Are you using MobileTrack or MobileRun from your phone?
Please add as more details as you can!
See you around.
Best Answer07-16-2018 08:27
07-20-2018 05:59
07-20-2018 05:59
