07-10-2018 11:39
07-10-2018 11:39
My Zip got moisture in it while it was in my sock and I was exercising two days ago. Now the Zip is not syncing with my Android phone. The phone does not even show the Zip as visible in Bluetooth. Removing the battery and restarting the Zip is not working. The Zip still shows steps and other information when restarted. I have dried the Zip out with rice and there is no visible moisture in the screen. But the Zip is still not visible as a Bluetooth device with my Android.
Help, would like to keep my steps up.
Best Answer07-10-2018 11:47
07-10-2018 11:47
Hi @kentpenney
After the rice did you clean it out with alcohol on a cotton swab and put in a fresh battery?
Let us know what happens.
Best Answer07-10-2018 12:59 - edited 07-10-2018 13:00
I cleaned with a swab and did put in a fresh battery. I could not clean any deeper than the back of the circuit board though.
Best Answer07-10-2018 13:08
07-10-2018 13:08
How old is the little Zip @kentpenney ?
Some of these have gone through the washing machine and dryer and survived.
Best Answer07-10-2018 13:15
07-10-2018 13:15
It is just 2 years old. Luckily I have not sent it through the washer.
07-13-2018 10:31
07-13-2018 10:31
How you doing my friend @kentpenney? Welcome! Thanks for the support @Odyssey13.
Thanks for posting your inquiry here. Sorry what happened to your little friend, I noticed you tried all the possible steps to save him with no luck. So, I got in touch with our support team to check your case and they've explained to me that you already talk to them about this. If you need more information about your warranty options, please let me know.
Have a good one.
07-18-2018 06:34
07-18-2018 06:34
Here is my conclusion to the problem. For me the solution was replacing my Zip. I got the new one and it is now syncing and working correctly. I think part of the problem was the battery cover had started to split and it was not possible to get a replacement battery cover. If I had been able to get a replacement cover, which I would have gladly paid for, I would not have gotten perspiration into the Zip and had to buy a new Zip. It would be nice if replacement covers can be made available to people in the future to avoid these issues.
Problem solved for me now.
07-20-2018 09:12
07-20-2018 09:12
Thanks for the update @kentpenney. I don't think we currently have plans to release this feature,but thanks for taking the time to share your feedback with us and we will let you know if anything changes. I'm glad to see that you're back on track though.
Let me know if you need anything else.
