03-28-2015 06:35
03-28-2015 06:35
03-28-2015 07:54
03-28-2015 07:54
You can go the activities tab in the log (you end up here: https://www.fitbit.com/activities )
Make sure the "steps" button is selected and enter the start and end date for the month. This should give you the total you are looking for.
10-22-2017 20:47
10-22-2017 20:47
How to do this in mobile app?
10-27-2017 19:39
10-27-2017 19:39
Awesome help @SteveH! 😉 Welcome to the Community Forums @duskov! In your app, to tap on the daily activity tile the goal you want to see. There you will be able to see your totals per week.
If you tap the bar chart it will display the totals per week, month, 3 months or 1 year.
I hope this helps, keep me posted! 🙂
10-27-2017
23:32
09:25
YojanaFitbit
10-27-2017
23:32
09:25
YojanaFitbit
Thanks on the welcome. The will show average per day, not total. It would
be good if tap on “average” would switch between average and total.
Tried on iPhone.
Moderator edit: Removed personal information.
02-01-2019 08:35
02-01-2019 08:35
Nope. the mobile app does not show you the number of steps in a Month. Only the average.
How difficult would it be to add this very useful feature? How on earth did no one at FitBit ever think of this before? I am I just a far-sighted FitBit genius?
02-08-2019 09:47
02-08-2019 09:47
Hi @dlwiii, welcome to the Forum!
Thanks for sharing your feedback with us. I'd like to check some details with you since, I've checked the Fitbit app and I can see the total amount of steps and also the daily average. Open the Fitbit App >tap the tile of steps > Tap the graphic of the week > Chose the option 1 month > swipe right to see more dates.
If you would like to pick exact number of days, you can use the option that our good friend @SteveH suggested here.
Keep me posted.
04-24-2019 19:40
04-24-2019 19:40
Still having trouble with this ”totals” thing...I’m not seeing totals but only monthly average...could it be it is not available to me? I’m involved in a monthly challenge so I’d like to get this figured out before May 1. Thanks
05-02-2019 19:21
05-02-2019 19:21
Yes Fitbit this would be a very helpful feature on the mobile app!!!
05-07-2019 07:27 - edited 05-07-2019 07:30
Hi @Liz0103 and @Mtwidale nice to see you on the Forums. It's great to have new members around. Sorry for the delayed response.
As you can see on the picture posted above. The Fitbit app has the option to show the monthly total of steps and the average too. If you're not able to see this image, please make sure that your app is up to date and open the Fitbit App > tap the tile of steps > tap the graphic of the week > chose the option 1 month > swipe right to see more dates.
Keep me posted on the resolution and good luck on your monthly challenges @Liz0103.
05-07-2019 17:43
05-07-2019 17:43
05-07-2019 17:43
05-07-2019 17:43
I can get to the 1 month average but from there, there’s no swiping available.
05-07-2019 20:41
05-07-2019 20:41
Same comment as Liz. I can get to the “1 month” option but it only shows the average daily step amount for the month, not total steps. See screenshot attached.
05-27-2019 16:08
05-27-2019 16:08
It only shows the average steps, not actual amount for week, month, or year.
07-06-2019 15:31
07-06-2019 15:31
Do u have iphon.
I have heard its a problem with iphons
07-06-2019 17:55
07-06-2019 17:55
10-13-2019 11:20
10-13-2019 11:20
Any plans to fix this? Seems pretty fundamental. My 4 year old Garmin did this seamlessly. Planning on switching to an AppleWatch when this Versa dies (again). It’s really disappointing to not be able to look at all the progress I’ve made. 😞
10-14-2019 03:13
10-14-2019 03:13
Same problem for me... 😞
02-25-2020
13:23
12:19
JuanJoFitbit
02-25-2020
13:23
12:19
JuanJoFitbit
Seems iPhones app doesn't show total, only average per month, like the support staff showed in his/her screenshots. I can get monthly total on desktop dashboard, though. I would also like to see monthly total on iPhone mobile app.
monthly & yearly totals available from desktop dashboard view.
Moderator edit: merged reply
04-11-2020 07:33 - edited 04-11-2020 07:38
