09-07-2017 17:52
09-07-2017 17:52
HELP!!!!! I HAD TO REPLACE MY ZIP BATTERY THIS MORNING, clipped it on me and went about my day and here I is close to 6pm i try to sync and the counter is at 0?!?!?!?!?!??!?!?!??!
Best Answer09-08-2017 06:48
09-08-2017 06:48
Hi @Raven6649 - Yep, that's frustrating! Is your tracker showing zero steps, or is just not syncing? If the tracker is showing zero steps after replacing the battery, please take the battery out and put it back in. That will restart your tracker and hopefully correct the issue. If your tracker is recording steps, but not tracking, check out the troubleshooting in the help article below.
Best Answer09-19-2017 19:19
09-19-2017 19:19
I had the same problem. I replaced my battery and when the Zip turned back on, it erased ALL MY STEPS! I had over 2.5 miles. Now it shows ZERO! I tried removing the battery and putting it back in as suggested. NO LUCK!! Now what do I do? I really hate this ZIp battery stuff. It never works right!
Best Answer09-22-2017 10:33
09-22-2017 10:33
I am having the same problem. Very frustrating.
Best Answer09-23-2017 04:58
09-23-2017 04:58
I can go one worse... I replaced my battery (which was full) and now nothing! My app showed 1/2 battery but my screen was dead and it had not registered any of my steps for yesterday... HELP!!!!!
Best Answer09-25-2017 04:37
09-25-2017 04:37
This happened to me and I called Customer Support who helped by resetting the Fitbit and talking me through what to do.
Best Answer09-25-2017 16:15
09-25-2017 16:15
