10-11-2016 17:40
10-11-2016 17:40
Best Answer10-12-2016 04:45 - edited 10-12-2016 12:06
Hi there @JaniHennes, welcome aboard to our Community. Thank you for your feedback about the need of a new design for the Zip clip. I will pass your comments to make sure this feedback is share with our teammates.
I wonder if your Zip keep coming off from the rubber case or is the whole tracker with the belt clip that does not stay in place?
If is the pebble that goes inside the tracker the one that keep coming off, perhaps is the belt clip too wear and may need a change (you can find replacements in the Fitbit Store), since the tracker should remain secure inside the belt clip. If is the whole unit that does not stay secure, I recommend recommend attaching it so that the display faces your body for maximum security.
Hope these tips helps. If you have more questions let me know and thank you again for your feedback.
Best Answer10-12-2016 06:46
10-12-2016 06:46
Best Answer10-13-2016 04:23
10-13-2016 04:23
HI there @JaniHennes, thank you, indeed a full cover wold be nice. I was looking if there was a similar idea in our Feature Suggestion board, but I wasn't able to find one.
This is the best place to make your voice heard, so you are welcome to share your idea in our Suggestion Board. Our product team looks forward to reading and incorporating your suggestions into future versions of Fitbit trackers and apps.
See you around and keep participating in our Community.
Best Answer10-14-2016 06:47
10-14-2016 06:47
Best Answer10-17-2016 04:39
10-17-2016 04:39
HI there @daisykat, good to see you here. I have never seen a watchband for the Fitbit Zip. But I'm glad you have found one that it works for you.
Just keep in mind these products are made by a third party and are not officially supported by Fitbit. So it might enter in conflict with the warranty policies if something goes wrong.
See you around and thank you for sharing this.
Best Answer10-17-2016 06:11
10-17-2016 06:11
