02-11-2018
10:13
14:31
LucyAP
02-11-2018
10:13
14:31
LucyAP
Hi I've bought the Fitbit Zip it arrived last Monday I set it up bout 7pm that day and on Friday I received a e mail telling me my battery was empty is this normal so put new one if so it is very disappointing thanks
Welcome to the Forums @c_a! This sounds odd. Please make sure that the CR2025 battery is correctly placed. Your Zip's battery should have the + sign on the top.
Keep me posted with the outcome! 😉
Thanks for the update @c_a! So good to hear that you are back on track! Please feel free to post back if you have any other question or if you need extra help.
Also, I'd like to encourage you to join us at the Discussions board, there you can be inspired, find some tips to get moving, eat well, manage weight, sleep better, live mindfully and more!
Give it a look!
I have the same problem, the battery is in correct. On the dashboard it still says low battery. This is the 2nd battery in 2 months (thought I had gotten a bad one) and just don't understand. It is Lithium Cell CR2025 3V. Thank you for any suggestions, Carol
Welcome to the Forums @the4fuzzies! Thanks for sharing your experience with the Zip tracker. To make sure that your tracker is working correctly you can restart it.
Also, you can make sure that the battery is working as it should. In this case, I would recommend checking the metal spring inside the Zip's battery compartment. Sometimes your tracker will have battery issues when this is bent. You can watch the post by @vomitofthemind to know how to fix your spring.
I hope this helps, keep me posted! 🙂
How you doing @Mrgttm? Thank you for reaching out to the Community.
That's a good question. The Fitbit Zip battery should last up to 6 months before needing a replacement. Frequently tapping your tracker to check your statistics may reduce battery life. If you need more details about battery, you can find more information here: Can I improve my Fitbit device's battery life?
Let me know if you have questions.
