05-31-2017
12:44
14:16
KateFitbit
05-31-2017
12:44
14:16
KateFitbit
Has anyone else noticed that when they track exercise it sometimes saves and sometimes doesn't? When it doesn't save I have to log it manually and it ends up seeming to give me more steps on my dashboard than I think I've done
Moderator edit: title for clarity
This has also happened to me several times. The walk will log on the map, but when I go back to the main app screen after finishing my walk it does not always show up. So instead of showing 3 or 4 days walking, it might show just one for the week. Other weeks it will show every walk. Any ideas on what is causing this?
13:06
07:29
06-20-2017
13:06
07:29
@bgwalks, @Pooky0711, Welcome to the Community, nice to see new faces. @Myhushpuppy Nice to see you back.
It sounds like you are using MobileRun to track your exercise through the Fitbit app. If you haven't already, try logging out from the app, restart your mobile device and then log back in again. That sometimes helps. Also as @LucyAP mentioned above, make sure you are on the latest version of the app.
I'm also including the help article on MobileRun here, it explains a bit about how it works and may help find a solution.
@Myhushpuppy, I'm not sure if you are getting duplicate steps from MapMyWalk, but manually logging activities should not result in double steps. When manually logging an activity, step and calorie data override the data automatically detected by your tracker during the same time period.
Hope this helps!
Actively managing your weight? Find accountability buddies on the Manage Weight board
@KateFitbit, what version is the most current for Zip? Also, I retried adding my 2.4 mile run I did on treadmill and my steps went from 11500 to 17500. I added it for the 54 minutes fitbit registered I was active but how do I keep the written log of miles or have my activity for the day be marked as complete if it only logs gps activity and I'm on treadmill?
