Can I use more than one machine for my account?
I finally got zip to work with my macbook Pro. So, I set up the device on that machine. Can I do that with my windows 10 machine (not mobile)? ? Which would entail taking out the dongle from the mac to set up on the windows.
Hello @Carol4x,
If you install the Fitbit App on Windows 10, you don't need the dongle to sync. You can do it through just bluetooth LE.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
Best AnswerAlready tried both ways-driver error on both. My driver was updated-still driver error. It worked once on my apple and now it does driver error as well. My main computer is an all in one with Windows 10 my laptop is a Macbook Pro 13 with El Capitan.
Both having driver error problem. Still cannot sync
I have a Zip
Best AnswerThe apple one is now working fine. windows 10 one is still no go-still driver error.
So, it looks like I will keep to the apple one. Just tired of fooling with it.
